October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow to work with STL file?
October 17, 2017 at 10:15 am
cbhavsar
Ansys EmployeeOne cannot import an .STL file directly into Mechanical. However one can convert .STL file into CAD file through Spaceclaim and then import the CAD file into Mechanical. Generally .STL files are not able to capture geometry appropriately and Spaceclaim helps to repair the .STL file if needed.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
