August 1, 2018 at 7:58 pm
shazimy
SubscriberHello All,
I am working on generating mech in ICEM cfd and connecting it to CFX in workbench for optimization. The problem is that in CFX I don't have all my parts defined imported, just one "Principal 2D Rejoins" shown under ICM.msh that is all faces. It does not have any issue transferring to Fluent. It is just in CFX. I tried many ways following different tutorials but still not showing.
I would appreciate it if you could support me.
Shahab
August 2, 2018 at 10:40 am
Ansys EmployeeICEM CFD isn't as straightforward as using ANSYS Meshing. If you do need a full hex mesh then you may need to use it; otherwise I'd suggest switching to ANSYS Meshing.
Have you connected the ICEM CFD and CFX components in WorkBench?
August 2, 2018 at 4:38 pm
shazimy
SubscriberHello
I installed the Ansys version 18.1.
It works perfectly exporting boundaries. Issue in 19.0 and 19.1.
However, not successfully be able to update. So working on modifying the script. I think something not working in the resent version. Would you check it and update me.
Regards
Shahab -
August 3, 2018 at 12:29 pm
Ansys EmployeeDoes it work as expected from scratch in R19 when you do a test manually?
August 3, 2018 at 4:02 pm
shazimy
SubscriberHello Yes, everything is similar If you provide a secure link, I can email the archive to you to see.
Regards, -
August 3, 2018 at 4:29 pm
Ansys EmployeeFeel free to post on here for the community to view; as ANSYS staff I'm unable to answer specific problems. We are able to offer general advice etc as this is a public forum.
2630
2110
1335
1110
461
