Platform
Platform
Workbench and Mechanical crash on startup
    • wdavid
      I've recently come back to ANSYS for a new project, but am unable to open the software. Some components open fine, but the Workbench and Mechanical crash after reaching 'Initializing Project' on the loading screen. I've tried restarting and re-installing but am still having the same issue.
      In the Windows Event viewer I'm getting this application error which I'm told suggests a corrupted file, but I don't see how this could be the case and still persist after re-installing?
      Any thoughts welcome, am at a loss as to what I can try
    • George Karnos
      Close all ANSYS programs.
      Open Windows File Explorer and then type in the following in the address line:
      %APPDATA%\Ansys\v222
      hit enter
      You should see a directory named:
      Rename this directory to:  v222.old
      Now try to run.
    • wdavid
      Hi George,
      Thanks for the response and help. What directory am I meant to be renaming, sorry? I think you missed it off
    • George Karnos
      @wdavid,
      My apologies for the typo!
      Go to:
      %APPDATA%\Ansys\
      hit enter
      You should see a directory named: (V2## depeding on version installed)
      If version 2022 R2:
      v222
    • wdavid
      Thanks. I did this and, it created a new directory v222. However, the problem is still not solved, still crashes on the 'initializing project' screen
    • wdavid
      Problem solved - My anitvirus wasn't letting it through
Viewing 5 reply threads
