Workbench File Opening Error
    • hani.sadek_i
      I am trying to open an old work bench file but it is not opening and it shows the bellow error
      How can I solve that problem ?
      I currently have ansys 2021R1, and that file was prepared using 2018 (I don't know if this is related to the current error)
    • Navya C
      You can try the following.
      Rename the file you want to open with a shorter name.
      Move the files you want to open a few folders above. It looks like the file location path is too long.
      Regards Navya
    • hani.sadek_i
      Thank you !
