February 22, 2023 at 9:36 pm
s_safiza
SubscriberHello,
I am trying to write a job script to submit my simulation on our university's cluster. We don't have an RSM license so we should generate our own job script and submit it on a Linux system. My simulation is on Workbench and the job script that I have generated is below:
The problem I have is that I am requesting more than 8 cores from the cluster but Ansys only uses 2 cores! I need to add a command to ask Workbench to use the requested cores and memory from the cluster. I know for Ansys mechanical the command is "-np" but for Workbench, it is not defined. I would appreciate it if anyone knows what command should I add to use the requested resources from the cluster.
Thanks in advance.
February 23, 2023 at 9:12 am
Erik Kostson
Ansys EmployeeHi
First of all try to get RSM as this is the easiest way – talk to your University , but I do not think there is not a licence (RSM), and a cost for that as far as I know
Not that straight forward. You need to supply a script (.py) in the batch line using the -R argument:
runwb2 -B -F “D:\\OTHER\\sunbatch\\test.wbpj” -R ” D:\\OTHER\\sunbatch\\test.py”
The test.py can include the settings as :
config2 = ExtAPI.Application.SolveConfigurations["My Computer, Background"] x = config2.Default y = config2.Settings.License z = config2.SolveProcessSettings.ManualSolverMemorySettings.Workspace config2.SolveProcessSettings.ManualLinuxSettings.UserName = "jane.doe" config2.SolveProcessSettings.MaxNumberOfCores = 12
See here for more info:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/act_script/SolveProcessSettings.html
All the best
Erik -
March 1, 2023 at 8:44 pm
s_safiza
SubscriberHello,
Thank you for replying. Honestly, I tried to make a .py file including the script as it was mentioned in Ansys help as the link you sent me. But still, the analysis is done with only 2 cores. I included the screenshots below.
Would you please let me know if you have any suggestions? Thanks a lot.
Kind regards,
3930
2649
1861
1272
610
