Ansys Products
Ansys Products
Workbench launching error due to home directory, how do I change home directory
    • hanumaha
    • Matt Madore
      You should check with your IT as this should be changed at the system level. You might try setting these in a command prompt and then launch Workbench from that command prompt, or create a batch file that sets HOMEDRIVE and HOMEPATH and then launches Workbench.
