March 23, 2021 at 1:09 pm
aozer
SubscriberHi There,nRecently working on eroding contact in Workbench Ls-Dyna. The question is how to define eroding contact in WB Ls-Dyna. There is not default menu under analysis settings just like WB Autodyn. I tried to add from Ls-Dyna Pre menu Contact Property then selected body interaction define eroding. But it did not work. It passed to other side of the panel but panel does not erode. I also changed a few things on details of contact properties in Advanced control card according to instructions but i could not erode panel. Where is the problem.n Thank you.n -
March 24, 2021 at 4:04 pm
Kai
Ansys EmployeeHi aozer,nYou will need Keyword Snippets to replace the existing contact logic with eroding contact logic. This is not included in workbench ls-dyna GUI.n -
March 25, 2021 at 7:51 pm
aozer
SubscriberHi Kai,nThank you your comments. What kinds of snippets? Do I need to enter them with comment prompt? Could you give some example?n
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
