Ansys Free Student Software
Workbench not opening
    • Liis Tammekand
      Hello
      I have used Workbench for some while now, but it does not open in my computer anymore. Last night I saved my project and closed it. Today it does not open properly - it shows, that it is open and I can see the icon but the program itself is still closed.
      What to do? Any help is appreciated. :)
    • peteroznewman
      Hello Liis,
      Do you ever plug a second monitor into that computer?  I sometimes have my laptop with a second monitor plugged in while using Workbench. Then later, when I don't have the second monitor plugged in, I start Workbench and the icon shows in the taskbar, but the window is not on the laptop screen. Unfortunately, the computer has saved the monitor Workbench last used to put it on the same monitor the next time even if that monitor is not plugged in!
      Is it possible that has happened to you?
      To recover from this, I can plug the second monitor back in and find the Workbench window.
      There is another trick I can use if I can't plug the second monitor back in. Right click on the icon and start a second copy of Workbench. Right click on the icon and select Maximize. That will snap a Workbench to the current monitor.
    • Liis Tammekand
      Hey peteroznewman,
      Thanks, it worked!
      Haven't had this problem earlier. :)
