November 8, 2017 at 4:03 pm
Adil_om
Subscriberworkbench doesn't work with me. it doesn't show any error
I have trued ansys 17.2 and 18.2 student version and i have the same problem.
Windows 8.1
November 8, 2017 at 7:42 pm
Raef.Kobeissi
SubscriberAre you opening it through Workbench after your solution is solved? What happens when you try to open it?
Cheers -
November 8, 2017 at 8:34 pm
Adil_om
SubscriberWorkbench doesn't open sines I install it
When I click on it the mouse turn to the loading icon than nothing shows up
Thanks
November 9, 2017 at 8:28 pm
Raef.Kobeissi
SubscriberIs your windows up to date? And your other drivers up to date? Could you also try to open cfdpost straight from the application rather than opening it from Workbench and tell me whether it works or not.
Cheers -
November 11, 2017 at 8:15 am
Adil_om
SubscriberThe windows and drivers has updated
What do you main by cfdpost straight?
Thank you
November 11, 2017 at 8:57 am
Adil_om
SubscriberI found the cfdpost
yes it dose work
November 12, 2017 at 4:10 pm
Adil_om
SubscriberCan you reply please
I need the program for the project
thank you
November 13, 2017 at 8:00 pm
SubscriberHere is a definitive guide to installing ANSYS Student 17.2.
Installing ANSYS Student 18.2 is much simpler, just Run as Administrator.
November 14, 2017 at 3:49 am
Adil_om
SubscriberI have Installed 18.2 and still same problem
November 14, 2017 at 12:24 pm
Vishal Ganore
Ansys EmployeeWhich graphics card are you using?
November 14, 2017 at 1:59 pm
Adil_om
SubscriberIntel(R) HD Graphics 4600
November 15, 2017 at 10:01 am
Vishal Ganore
Ansys EmployeeHave a look at this thread for possible graphics card issue. ANSYS supports NVDIA and AMD.
https://forum.ansys.com/forums/topic/geometry-editor-was-closed-abnormally/
November 26, 2018 at 10:19 am
November 26, 2018 at 7:45 pm
tsiriaks
Ansys EmployeeHi pozs,
Please try resolutions discussed here
https://forum.ansys.com/forums/topic/installation-problem-in-workbench-19-2/
If that doesn't help, please create your own/new thread.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2726
2156
1359
1150
462
