June 8, 2023 at 6:23 pm
Sree Ranjini
SubscriberHello,
The template of e4a IN MOTORCAD throws up some errors. Can anyone share actual working model of e4a
June 9, 2023 at 11:01 am
Navya C
Ansys EmployeeHi Sree Ranjini,
I am on MotorCAD version 2023.1.1.1.
e4a template ran without any errors for me.
Are you doing any modifications to the template or the base template itself is giving you errors?
Can you check if you are on the same version? If you still face the problem please provide the message manager window screenshot with errors.
Navya
June 9, 2023 at 11:24 am
June 9, 2023 at 11:53 am
Navya C
Ansys EmployeeIt may be a warning message and not an error.
It could be because the bus voltage is not sufficient enough to supply the required current which is a design-related problem.
Please refer to the below forum discussion for more details.
MotorCad – How can I avoid this warning ? (ansys.com)
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2969
1449
1322
