Preprocessing
Preprocessing
Working on tutorial (Chapter 2: Parametric Analysis in ANSYS Workbench Using ANSYS Fluent)
    • Tareq
      Please i am working on ansys tutorial chapter 2 (Chapter 2: Parametric Analysis in ANSYS Workbench Using ANSYS
      Fluent), but once i update the meshing i receive the following error:
      "The tolerance of the geometry is larger than the applied tessellation refinement tolerance. This might lead to an uneven mesh and/or to poor geometric accuracy of the mesh"
      I am following the tutorial step by step, why this occur?
      Thanks alot
    • Vishal Ganore
      Could you please share your project file achieve to find out what is happening? Which version are you using?
