March 13, 2021 at 1:11 am
Guanhui Wang
Ansys EmployeeThis page provides some basic information about the Poynting vector.
Definition
The Poynting vector is defined as follows. Poynting vector data is generally obtained from frequency domain monitors, with the CW normalization option enabled. In such cases, the steady-state Poynting vector data will have units of Watts/m2
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1285
1096
459
