January 6, 2023 at 10:24 am
Xime54
SubscriberHello everyone,
I am currently working with the "virtual photometric lab".
1) I get an energetic illumination that I want to convert into an exposure: I have to multiply each pixel of the map by a scalar (typically a time in seconds). Is this possible and how to do it?
2) I want to compare this exposure to a reference exposure: use the "map comparison" or "map calculation" tools. How to create a map that corresponds to my reference exposure?In general, where can I find tutorials on how to use this tool?
Thanks to you. -
January 9, 2023 at 7:07 pm
Fasehur Mohammed
SubscriberHi,
- there's two ways to do this-
- use the rules in the measurement window- Operators and Functions for Global Rules (ansys.com)
- export a line of pixels to a excel sheet and then apply formula there. for this you can select a shape
use 2d view section and then export as txt.
2. Im not familiar how to do this. if its two maps then you can use map calc as a comparison. I will ask a colleague to respond on that.
BY pressing f1 under the viewers selection in SPEOS will get you to the use guide for the Photometric lab
Please contact me if you have any further questions.
January 10, 2023 at 3:03 pm
Xime54
SubscriberDear Mohammed,
Thank you for your feedback, I will look further into the sbject.Maxime
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- How to calculate the cross-polarization efficiency and phase in FDTD
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2600
2088
1319
1108
459
