July 16, 2021 at 8:01 am
ciema
SubscriberHello i need to find document that explains better than help Available Solution Quantities, that are displayed in Worksheet.
July 19, 2021 at 3:20 pmGovindan Nagappan
Ansys EmployeeSee if this helps: User Defined Results for the Mechanical APDL Solver (ansys.com)
From help section:
Element-based user defined results can exist at the nodes (like stress and strain) or can exist at the centroid (like volume)
Node-based user defined results are most often associated with degree of freedom solutions (like nodal reactions)
July 20, 2021 at 6:50 amciema
SubscriberThank you gnagapp.
I cannot find there only one thing. What is the difference between UX and UALLX , UY and UALLY , USUM and UALLSUM ?
I know what is the definition of UX but how about UALLX and this kind of results? They are presented on the end of Available Solution Quantities table.
July 20, 2021 at 11:50 amMickMack
SubscriberHi Ciema The differences relate to the quantification of the component as shown in the snippet.
The answers will be in the ansys help. For example for contour results they may come in three types as nodal, elemental or elemental nodal. They then have various styles as shown below, i have also attached the link to this page.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/act_script/mech_apis_Contour_Results.html?q=USUM
There are separate results depending on what elements have been used in your model. If you are using BEAM188 refer to this in the help section and you get a list of element outputs.
Similar if you are using a COMBIN39 element you can use the expressions provided in the table below to create your own User Defined Results.
Trending discussions- Solver Pivot Warning in Beam Element Model
5290
3311
2471
