我在处理杆单元给他施加预应力时,想沿杆的轴线方向施加。选择单元坐标系说是可以从i节点到j节点施加,但我看应力云图,最大位置在整体坐标系x处,施加到了整体坐标上了好像,怎么施加到单元坐标系上啊 I
    • yafengliu
      I am applying prestress along the axis of the link180 by using inistate command. The element coordinate system says that INISTATE can apply prestress from node I to node j, but I look at the stress cloud. the maximum position of the stress cloud is at the global coordinate system x. i think i had applied to the global coordinate system possiably, how do i apply it to the global coordinate system?
      inistate,set,csys,-2  !Isn't that assigning to the unit coordinate system?
      inistate,defi,9,,,,1605000000
    • April Wang
      The commands look correct to me. Could you try to apply the load on another link180 element to see if it make any difference?
      Inistate 看上去用的是对的,你尝试换一个element id试一下,看结果是否改变,来判断是不是加在整体坐标上了
      April
