write_ECE_to_json
    • Krz
      Hi everyone,
      I'm trying to export an ECE mode to a ".json" file.
      This needs a script which is called "write_ECE_to_json". But I don't know how can I get that.
      I appreciate any help.
      Thanks
    • Chinmay T
      Please let us know which Ansys tool you are using.
      how you got to know that "write_ECE_to_json" script is needed to export a .json file and what is your end goal?
      Thanks,
      Chinmay.
    • Krz
      I got a presentation file that shows how to export .json file step by step. At one of the steps the script "write_ECE_to_json" is used.
      Recently I downloaded that script from OPAL-RT website. Now the problem is that Position and Torque graphs are created successfully and are ready to export, but Flux Linkages and Inductances graphs can not be created.
      The final goal is to export .json file which contains machine parameters for several operation points.
      I hope the attached pictures help.
      Amir
