August 11, 2018 at 7:03 pm
Punnag Chatterjee
SubscriberHello all, I am finding it difficult to write a command snippet to export a displacement probe tabular data from ANSYS Workbench 19.1>Transient Mechanical module. The following code does not seem to work.
*cfopen,simple,txt
*VWRITE,Time(1),Dy(1)
(F10.0,F10.0)
*cfclose
I am clearly making some mistakes in the command snippet code.
I have already created the file 'simple.txt' and placed it in the working directory:
'C:ANSYS Analysis filesFull_transient_and_MSUP_Peter_files'
Nothing gets written and the file is empty, I cannot figure out the reason.
August 30, 2018 at 1:26 pm
jpasquerell
Ansys EmployeePost processing command objects have no default data so you need to store the data via the set command. I would first recommend trying a right mouse pick on the Dy and try exporting it that way. If not then the command object would be based on this (and it would be at the node nearest the x y z location). I did not test it and I believe it will not like time as an array name so you may need to use a different array name:
xnod=1.2 ! change to be the desired global x location
ynod=3.4 ! change to be the desired global y location
znod=5.6 ! change to be the desired global z location
set,first
nnod=node(xnod,ynod,znod)
*get,numres,active, ,set,nset ! count of results sets
*dim,time,array,numres
*dim,dy,array,numres
*get,time(1),active, ,set,time
*get,dy(1),node,nnod,u,y
*do,jj,2,numres
set,next
*get,time(jj),active, ,set,time
*get,dy(jj),node,nnod,u,y
*enddo
*cfopen,simple,txt
(F10.0,F10.0)
*cfclose
September 3, 2018 at 7:04 am
January 28, 2019 at 6:47 pm
Punnag Chatterjee
SubscriberHi,
Thanks for the reply. I am already aware this method. I wanted a code based solution so as to automate the process since I would be doing the operation over multiple iteration cycles. Thanks.
2120
1349
1136
461
