Ansys Products
Ansys Products
Writing Injection files for DPM
    • Salix Bair
      Is covered in the Fluent User's Guide. You may want to be a little more specific.
    • Salix Bair
      I am trying to create an injection file to be read into fluent, what is the format that is required? I haven't been able to find any resources in the Fluent Guide on how to create an injection file not using Fluent.
      You didn't see this https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_sec_discrete_initial.html%23flu_ug_sec_discrete_file_props  ?
    • Salix Bair
      I saw that, but am not sure what the file extension is. I tried using ".inj" with the following formatting, and Fluent was unable to read the file and produced the following error:
      Error: ASSQ: invalid argument [2]: improper list
      Error Object: 3.53558e-05
      ((.02    3.53558E-05    0    2    0    0    2.00E-09    296.15    0))
      ((.02    6.12395E-05    0    2    0    0    2.00E-09    296.15    0))
      ((.02    7.90619E-05    0    2    0    0    2.00E-09    296.15    0))
      ((.02    9.35496E-05    0    2    0    0    2.00E-09    296.15    0))
      ((.02    0.000106078    0    2    0    0    2.00E-09    296.15    0))
      ((.02    0.000117277    0    2    0    0    2.00E-09    296.15    0))
      ((.02    0.000127496    0    2    0    0    2.00E-09    296.15    0))
      ((.02    0.000136956    0    2    0    0    2.00E-09    296.15    0))
      The wild card doesn't matter, Fluent will just read what's in the file. Try adding the header, and review the brackets. An easier approach is to write a DPM out file from a case and compare the formats.
    • Salix Bair
      When I write an injection file from a case to compare the format, it doesn't match what is listed in the manual, this is what it looks like...
      ((particle_10nm_50000 ((type . inert) (injection-type . group) (cone-type . solid-cone) (numpts . 5000) (dpm-fname . " ") (surfaces . #f) (boundary -1) (stochastic-on . #f) (random-eddy-on . #f) (ntries . 1) (time-scale-constant . 0.15) (cloud-on . #f) (cloud-min-dia . 0.) (cloud-max-dia . 100000.) (material . water-liquid) (scale-by-area . #f) (use-face-normal . #f) (random-surface? . #f) (devolatilizing-species . #f) (evaporating-species . #f) (oxidizing-species . #f) (product-species . #f) (rr-distrib . #f) (rr-uniform-ln-d . #f) (evaporating-liquid-on . #f) (evaporating-material . #f) (liquid-fraction . -1.) (dpm-domain . none) (collision-partner . *dem-unknown*) (multiple-surface) (parcel-number . 500) (parcel-mass . 1e-09) (parcel-diameter . 1e-05) (parcel-model . 0) (drag-law . "udf LiuDrag::libudf") (shape-factor . 1.) (cunningham-correction . 1.) (drag-fcn . "LiuDrag::libudf") (brownian-motion . #f) (seco-breakup-on? . #t) (seco-breakup-tab? . #t) (seco-breakup-wave? . #f) (seco-breakup-khrt? . #f) (seco-breakup-ssd? . #f) (seco-breakup-madabhushi? . #f) (seco-breakup-schmehl? . #f) (seco-breakup-tab-y0 . 0.) (number-tab-diameters . 2) (seco-breakup-wave-b1 . 1.73) (seco-breakup-wave-b0 . 0.61) (seco-breakup-khrt-cl . 5.7) (seco-breakup-khrt-ctau . 0.5) (seco-breakup-khrt-crt . 1.) (seco-breakup-ssd-we-cr . 6.) (seco-breakup-ssd-core-bu . 1.73) (seco-breakup-ssd-np-target . 1000.) (seco-breakup-ssd-x-si . -0.1) (seco-breakup-madabhushi-c0 . 3.44) (seco-breakup-madabhushi-column-drag-cd . 1.48) (seco-breakup-madabhushi-ligament-factor . 0.4) (seco-breakup-madabhushi-jet-diameter . 0.001) (seco-breakup-schmehl-np . 1) (laws (law-1 . "Inert Heating") (law-2 . "Inactive") (law-3 . "Inactive") (law-4 . "Inactive") (law-5 . "Inactive") (law-6 . "Inactive") (law-7 . "Inactive") (law-8 . "Inactive") (law-9 . "Inactive") (law-10 . "Inactive") (switch . "Default")) (udf-inject-init . "none") (udf-heat-mass . none) (components) (volume-specification . zone) (volume-zones) (volume-bounding-shape circle 0 0 0 0 . 0) (volume-streams-spec . total-parcel-count) (volume-streams-total . 100) (volume-streams-per-cell . 2) (mass-input-on . #f) (rotation-on? . #f) (rot-drag-law . "none") (rot-lift-law . "none") (cone-type . "solid-cone") (uniform-mass-dist-on? . #f) (spatial-staggering/std-inj/on? . #f) (spatial-staggering/atomizer/on? . #t) (stagger-radius . 0.) (rough-wall-on? . #f) (cphase-domain . none) (x-pos . 0.002) (x-pos2 . 0.002) (y-pos . 1e-08) (y-pos2 . 0.004) (z-pos . 0) (z-pos2 . 0.) (ff-center-x . 0) (ff-center-y . 0) (ff-center-z . 0) (ff-virtual-origin-x . 0) (ff-virtual-origin-y . 0) (ff-virtual-origin-z . 1) (ff-normal-x . 1) (ff-normal-y . 0) (ff-normal-z . 0) (x-vel . 2) (x-vel2 . 2.) (y-vel . 0) (y-vel2 . 0.) (z-vel . 0) (z-vel2 . 0.) (x-ang-vel . 0) (x-ang-vel2 . 0.) (y-ang-vel . 0) (y-ang-vel2 . 0.) (z-ang-vel . 0) (z-ang-vel2 . 0.) (atomizer-x-axis . 0) (atomizer-y-axis . 0) (atomizer-z-axis . 1) (diameter . 1e-08) (diameter2 . 1e-08) (temperature . 300) (temperature2 . 300.) (flow-rate . 9.999999999999999e-21) (flow-rate2 . 9.999999999999999e-21) (unsteady-start . 0) (unsteady-stop . 0) (start-at-flow-time-in-unsteady-inj-file . 0) (interval-to-repeat-in-unsteady-inj-file . 0) (unsteady-ca-start . 0) (unsteady-ca-stop . 0) (vapor-pressure . 10000) (inner-diameter . 0.001) (outer-diameter . 0.005) (half-angle . 0.34906585) (plain-length . 0.001) (plain-corner-size . 1e-05) (plain-const-a . 4.9) (pswirl-inj-press . 1000000) (airbl-rel-vel . 100) (effer-quality . 0.08500000000000001) (effer-t-sat . 373) (ff-orifice-width . 0.001) (phi-start . 0) (phi-stop . 6.283185310001) (sheet-const . 12) (lig-const . 0.5) (effer-const . 0.3300000000000001) (effer-half-angle-max . 0.261799388) (ff-sheet-const . 3) (atomizer-disp-angle . 6) (x-axis . 0) (y-axis . 0) (z-axis . 1) (vel-mag . 0) (ang-vel-mag . 0) (cone-angle . 0) (inner-radius . 0) (radius . 0) (swirl-frac . 0) (total-flow-rate . 9.999999999999999e-21) (total-mass . 9.999999999999999e-21) (rr-min . 1e-06) (rr-max . 0.0001) (rr-mean . 1e-05) (rr-spread . 3.5) (rr-numdia . 10) (x-posr . 0) (y-posr . 0) (z-posr . 0) (x-posu . 0) (y-posu . 0) (z-posu . 0))))
      Which isn't what 21.3.13. Point Properties for File Injections  covers.
    • Salix Bair
      No, it doesn't cover the format written by Fluent. I have matched my format to that of the manual, Fluent won't read that format in. So on your suggestion, I wrote an injection file with the properties I want from Fluent, to see the format, which seems incredibly hard to replicate and there is no documentation on that format. I am just trying to write a file for a group of 500 particles, with a uniform diameter distribution, from the information listed in the manual this shouldn't be that difficult. I have READ the manual, I am looking for additional support to troubleshoot this which you don't seem to be able to provide.
      Erm, the format you showed earlier is not the format in the manual, which is why I suggested adding the header. If you've since revised the file you might want to share it?
    • Salix Bair
      I just copied and pasted the injection format from  21.3.13.1. Steady File Format of the manual to create a .inj file to be read into my case file. When I try to read the file in I get the following error:
      Error: CAR: invalid argument [1]: wrong type [not a pair]
      Error Object: z=4
      It worked OK here. Are you on Win10 or Linux?
      • Salix Bair
        I am running Windows 10
      Please post the top 5-6 lines of your injection file. I copied the header from the offline documentation and then added a couple of lines to create an injection without issue.
    • Salix Bair
      Here is my injection file:
      (injection 12)
      (          x           y            z            u            v            w     diameter            t    mass-flow         mass    frequency         time         name)
      (( 1.0000e-02   6.0000e-04   0.0000e+00   2.0000e+00   0.0000e+00   0.0000e+00   1.0000e-08   3.0000e+02   1.0000e-20   5.2266e-22   1.9133e+01    0.0000e+00) r=1mm:0)
      (( 1.0000e-02   6.0000e-04   0.0000e+00   2.0000e+00   0.0000e+00   0.0000e+00   4.5426e-08   3.0000e+02   1.0000e-20   4.8991e-20   2.0412e-01    0.0000e+00) r=1mm:1)
      (( 1.0000e-02   6.0000e-04   0.0000e+00   2.0000e+00   0.0000e+00   0.0000e+00   1.1628e-07   3.0000e+02   1.0000e-20   8.2166e-19   1.2170e-02    0.0000e+00) r=1mm:2)
      (( 1.0000e-02   6.0000e-04   0.0000e+00   2.0000e+00   0.0000e+00   0.0000e+00   1.0019e-06   3.0000e+02   1.0000e-20   5.2566e-16   1.9024e-05    0.0000e+00) r=1mm:3)
      (( 1.0000e-02   6.0000e-04   0.0000e+00   2.0000e+00   0.0000e+00   0.0000e+00   4.2611e-06   3.0000e+02   1.0000e-20   4.0436e-14   2.4730e-07    0.0000e+00) r=1mm:4)
      Getting this error:
      Error Object: injection
      Look very carefully at the second sample format in 21.3.13.1 and count your brackets.
      (z=4 12)
      (x y ....................... name )
    • Salix Bair
      So I realize that I was mixing my injection formats, I'm pretty sure I have the spacing and formatting correct now:
      (z=4 12)
      (x y z u v w diameter t mass-flow mass frequency time name)
      (1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:0)
      (1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:1)
      (1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:2)
      (1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:3)
      I'm still getting an error when I try to read it in.
      I also tried:
      (z=4 12)
      ( 1.0000e-02  6.0000e-04  0.0000e+00  2.0000e+00  0.0000e+00  0.0000e+00  1.0000e-08  3.0000e+02  1.0000e-20  5.2266e-22  1.9133e+01  0.0000e+00  r=1mm:0)
      ( 1.0000e-02  6.0000e-04  0.0000e+00  2.0000e+00  0.0000e+00  0.0000e+00  1.0000e-08  3.0000e+02  1.0000e-20  5.2266e-22  1.9133e+01  0.0000e+00  r=1mm:1)
      ( 1.0000e-02  6.0000e-04  0.0000e+00  2.0000e+00  0.0000e+00  0.0000e+00  1.0000e-08  3.0000e+02  1.0000e-20  5.2266e-22  1.9133e+01  0.0000e+00  r=1mm:2)
      ( 1.0000e-02  6.0000e-04  0.0000e+00  2.0000e+00  0.0000e+00  0.0000e+00  1.0000e-08  3.0000e+02  1.0000e-20  5.2266e-22  1.9133e+01  0.0000e+00  r=1mm:3)
      That looks fine, I assume it's all one line in the text editor? I wonder if frequency should be 1? We don't use files all that often (VOF to DPM is the exception) and I can't remember what it's exact purpose is.
      (z=4 12)
      (1 2 3 1 2 3 1e-5 300 0.001 0.1 1 0.001 injection:99)
    • Salix Bair
      I just tried with the frequency equal to one and as all one line, I thought each particle had to be a separate line, but still no luck. I think it might be time to try to pivot to a different solution for what I am trying to do... I am trying to create an even distribution of 500 particles over a large range of particle diameters to be injected from a single point. The linear diameter distribution option creates a distribution of particle diameters that is skewed to larger sizes. Is there a way in the set injection properties box to define an even distribution?
      I don't think so, and you're also looking at parcels rather than particles on the injection so it's a little messy.
      Try without the = in the parcel name.
    • Salix Bair
      Hi Rob,
      I tried it with the = in the parcel name, and that didn't seem to change anything. I think in an earlier post you had maybe said it was the text editor I was using, I'm using windows notepad...
      Try Notepad++  or something where you can show white space characters. It's the |P like symbol (View>Show Symbol in the newer version of ++). If you copied the header from the manual you're almost certainly going to have picked up a symbol or few.
      We tend to use ++ because it also shows up all the useful { } pairs and colours by command syntax once you save in a certain format, ie .c
    • Salix Bair
      I just switched to Notepad++ and I've gotten the closest to getting Fluent to read in the injection...I'm still getting an error, but fluent is now reading in the first argument:
      Importing the following injections:
      0.01
      Error: ASSQ: inInvalidrgument [2]: improper list
      Error Object: 0.0005999999999999999
      I switched over to this format as well: (( x y z u v w diameter temperature mass-flow) name )
      Do you need a parcel name? I've always used the other format. Also check the injection point is some distance into the domain, that should give a different warning but worth eliminating a potential issue when testing.
    • Salix Bair
      From the user guide: All the parentheses are required, but the name is optional.
      The injection is well into the domain. I'm injecting at x=10mm, and y = .6mm in a 60mmx2mm rectangle.
      2d? What happens if you remove the z coordinate & velocity header and values?
      OK, don't. A colleague just tried it and 2d does still add a z & w component.
      On re-reading the error it looks like Fluent is reading injection 0.01 and then failing.
Viewing 25 reply threads
