January 5, 2023 at 1:20 pm
Umut Can Gölbaşı
SubscriberHello,I am doing 2D analysis for plate heat exchanger. There is a 3mm gap between the plates. In the Ansys mesh section, I entered the thickness as 140mm.Based on the calculations below, my volume should be 420mm^2 (0.00042m^2).3mm x 140mm = 420mm^2 = 0.00042m^2However, as seen below, my area on fluent is 0.003m^2. Where is the problem?Thanks for your help. -
January 5, 2023 at 2:55 pm
Ansys EmployeeFluent assumes a 2d model is 1m thick, https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/flu_ug/flu_ug_sec_report_conventions.html
2656
2120
1345
1118
461
