Materials
Materials
Wrong Entery in ANSYS fluent material database?
    • Nicolo
      I am trying to simulate in ANSYS fluent 2020 R1, and I need to use formic acid from the ANSYS fluent database, but it seems to me that this material does not have the right values (density 1 kg/m3 and viscosity 1.72e-5). I have uploaded the picture.
      I also noticed that these values are reported for a large group of materials as well!!
      So given that my simulation is a two phase flow of formic acid and CO2 and there is not heat exchange involved, can I simply change the values in the box in fluent database and continue or I should write a new entry (and if so, please let me know how I should do it?)
      Thanks in advance
      You'll need to find data for those. Looking at the full entry it looks like it's intended to use a model to calculate density & viscosity as the molecular weight etc are there.
    • Nicolo
      Thanks Rwoolhou for the reply.
      So at this stage are you suggesting that I enter the value of density and viscosity manually from literature or choose a method like in picture (it also never asked me for a model for viscosity or to enter the viscosity manually after I chose the model for density.
      If I have to choose a method it would be great if you could give me suggestion on wich model I use?
      thanks in advance
      It depends. Given you're asking me I'd suggest finding a constant value in literature and use that. The alternatives are a lot more advanced and not something I'd try as a new user.
Viewing 3 reply threads
