Wrong results from thermosiphon model
    • boros989
      Hello Everybody!
      I am modeling a thermosiphon for cooling. The measurement for the given geometry portends 300 W heat transfer power. I developed first a 2D model and the mean power in time was in good aggreement with the measurement. I have done after the 3D model. You can see the geometry with dimensions below. But unfortunately the heat transfer power remained 2 order of magnitude lower from the expected 300W. Could anybody give me some tip for the reason ? If it necessary I will upload the settings images from Fluent. Thank you for your help!
    • DrAmine
      Which models are inlcuded?
    • boros989
      Helo Amine,
      pressure-based solver, transient, time-step: 0.0005 s, VOF, Energy equation: on, Standard k-e turbulence model, compressible-liquid density for water-vapour, Lee evaporation-condensation model
      Please note if I missed something!
      Best regards,
      Csanád
