Wrong results in ANSYS Fluent
    • 3LMOON
      I am using ANSYS fluent 2020 R1 in my MSc dissertation (University of Aberdeen) to model sea-water flow over a circular cylinder (fluid properties: density=1023.6 kg/m3,viscosity=.00091 kg/m.s) using 4 values of Re (100,1000,10000 and 10^6). I am trying to obtain drag coefficient and flow contour maps, but i am getting wrong results. Note that I have seen some tutorials on Youtube and I followed them but still getting wrong results different from what is available on the published resources.
      Check the reference area as drag coefficient is a derived quantity and the mesh: is it fine enough at the surface to pick up the shedding?
    • 3LMOON
      Thanks for your reply.
      the diameter of my cylinder is .6096 m. for the meshing my I put an element size of 300 mm and for the inflation I put an element size of 20 mm to have finer meshing around the cylinder.is it fine enough ??
      for the reference area as well as the length I put .6096 m.
      What would you suggest ?
      Check the sizing, and also try local refinement (adaption).
    • 3LMOON
      Thanks for your reply. I have done that but still getting wrong Cd values as well as the contour flow maps.
      What's wrong with the flow field? Pictures will help.
    • 3LMOON
    • 3LMOON
      As it is clearly seen that vortex shedding is not shown, although that Re = 100.
      Do you expect shedding at 0.15mm/s around a 0.5m diameter pipe?
    • 3LMOON
      As per my understanding, vortex shedding is a function of Re number. Also, from the literature it is mentioned that vortex shedding starts from Re= 40( critical Re) and in all my cases Re is higher than this value.
      If you have a better explanation as well as better understanding for this subject, I am happy with that and I will appreciate it, because my background is petroleum engineering so that I am not familiar to this subject.
      Thanks.
      Pass, I've not looked at the theory in years.  However at the speed you're using I'd not expect anything much to happen.
    • 3LMOON
      one more question, about the models, when to use each one??
      Thanks for your replies.
Viewing 11 reply threads
