August 12, 2019 at 3:31 pm
theodoreyang
SubscriberHello,
My 3D XFEM model offen terminates with the following error message:
*** FATAL *** CP = 204.958 TIME= 11:22:19
Unable to check if element 14776 is cracked since it is not a composite element.
I checked this element in the post-processing. This element is not adjacent to the crack front.
For 2D model, it always works well, but for 3D model, it can only solve very little substeps and stop with errors.
August 12, 2019 at 5:19 pm
David Weed
Ansys EmployeeHi Theodre, would you be able to post your APDL code? Thanks
August 12, 2019 at 5:27 pm
theodoreyang
SubscriberHi DavidW,
Here is the APDL code. Thanks.
/prep7
/com *** Geometry
length = 10.0 ! model centered at (0,0,0)
width = 10.0 ! geometry for each block
thickness = 10.0
xnum = 15 ! quantity of element on x
ynum = 15 ! quantity of element on y
znum = 20 ! quantity of element on z
et,1,185 ! element type
/com *** Material Properties *********************************
mp,ex,1, 2000.0
mp,nuxy,1, 0.3
mp,alpx,1, 52e-6
/com *** Model ***** centered at (0,0,0)**********************
/com *** Corner made by 7 small blocks
BLOCK, 0, length, 0, width, 0, -thickness/4 ! x1,x2,y1,y2,z1,z2
BLOCK, 0, -length, 0, width, 0, -thickness/4
BLOCK, 0, -length, 0, -width, 0, -thickness/4
BLOCK, 0, length, 0, -width, 0, -thickness/4
BLOCK, 0, length, 0, width, 0, thickness
BLOCK, 0, -length, 0, width, 0, thickness
BLOCK, 0, length, 0, -width, 0, thickness
vglue,all
/com ***mesh
type,1
mat,1
x_size = length/xnum
y_size = width/ynum
z_size = thickness/znum
lesize, 7, x_size ! element size on x
lesize, 8, y_size ! element size on y
lesize, 9, z_size ! element size on z
lesize, 97, x_size ! element size on x
lesize, 92, y_size ! element size on y
lesize, 85, z_size ! element size on z
vmesh,all
/com *************************************************************
/com
/com INITIAL CRACK DATA
/com
/com ***define crack position
x0 = 0
y0 = 0
z0 = z_size/2
xc = x_size/2
yc = y_size/2
zc = z_size/2
/com ***define enrichment identification***********************
esel,s,cent,x,-length*1,length*0.5
esel,r,cent,y,-width*1,width*0.5
esel,r,cent,z,-thickness/4,thickness/4
cm,testcmp_1,elem ! name the element set for xfenrich
allsel
xfenrich,ENRICH_1,testcmp_1 ! define the method: phantom node (default) or SIF
/com ***loop for crack level set identification***********************
esel,s,cent,x,x0-x_size*1,xc+x_size*0.499
esel,r,cent,y,y0-y_size*1,yc+y_size*0.499
esel,r,cent,z,z0,zc+z_size*0.499
cm, cenelem, elem ! name the element set for vertical crack elements
nelem = 1000
iel = 0
Phi = 0.0
Psi = 0.0
*do, i, 1, nelem, 1
iel = elnext(iel)
*if, iel, ne, 0, then
*do, j, 1, 8, 1
nd = nelem(iel,j)
Phi = nz(nd) - zc
xfdata, ENRICH_1, LSM, iel, nd, Phi
*enddo
*endif
*enddo
cm, crktipelem, elem
allsel,all
/com ******** Boundary conditions *********************
nsel,s,loc,x,0
nsel,r,loc,y,0,-width
nsel,r,loc,z,0,thickness
d,all,all,0
nsel,s,loc,x,0,-length
nsel,r,loc,y,0
d,all,all,0
nsel,r,loc,z,0
d,all,all,0
nsel,s,loc,x,-length-x_size/2,-length+x_size/2
dsym,symm,x,0
nsel,s,loc,y,-width-y_size/2,-width+y_size/2
dsym,symm,y,0
allsel
/com ******** Temperature load *********************
Tref,150
BF,ALL,TEMP,25
/SOLU
autots,on
time, 1.0 ! --- time
deltim,0.05,0.05,0.05
outres,all,all
tb,cgcr,1,,,STTMAX ! crack growth criterion, max circon stress
tbdata,1,3
tb,cgcr,1,,,RLIN ! rigid linear law
tbdata,1,0.04,,,0.05
CINT, NEW,1
CINT, CXFE,crktipelem
CINT, TYPE,STTMAX
CINT, RSWEEP,181,-60,60
CINT, NORM, 0, 3
CGROW,NEW,1
CGROW,CID,1
CGROW,METHOD,XFEM
CGROW,FCOPTION,MTAB,1
SOLVE
Save
/POST1
SET,LAST
2098
1323
1108
461
