Optical
Optical
xml template file does not apply correctly
    • Xime54
      Hi everyone,
      When defining an irradiance sensor, I put it in "spectral" and apply an xml template to quickly extract the values that interest me.
      I am interested in energetic units, but the results given are in visual units! See picture.
      When I manually apply the template, everything works fine and I got the results in energetic.
      Does anyone know fhe issue?
      Thanks.
    • Thomas Martineau
      If you change 'Display properties from file' to true in the sensor definition, you will have the measure in energetic units.
      The template must be generated in energetic unit.
      best regards
    • Xime54
      Thank you Thomas.
