February 14, 2018 at 11:40 am
jonheb
SubscriberHi there I was wondering if you could help me out with a similar problem.
I am modelling a micro channel with k omega SST turbulence and there is a constant heat flux also added at the wall of my micro channel.
I have modelled the micro channel as a smooth flow initially and have been getting a Y+ of 1 for Reynolds of 40k approx., but when I add a roughness ks of 9.84e-5 the Y+ is now 200+. I don't understand what I need to do in order to get it back to Y+=1 again, I have played with the bias of the mesh and tried increasing the number of cells but very little happens.
I am trying to see the sublaminar layer in so that I can see the effects of heat transfer.
February 27, 2018 at 5:44 pm
Raef.Kobeissi
SubscriberhI,
Adding wall roughness does affect the Y+ Value. To understand the relationship I advise you to read the documentation.
Regards
January 11, 2019 at 12:06 pm
mdfaizan444
Subscriberhey, i am working in a wavy channel in which i want to calculate y+ value... i tried to calculate from your website but it requires boundary layer length that i not know.. so plz help me regarding this. And also how to calculate the Nussult number in 2D flow, like as 3D flow will it be calculated from area weighted average?
January 11, 2019 at 12:16 pm
DrAmine
Ansys EmployeeFor channel there is some other correlations to get the friction factor. Check the blog of our partner: https://www.computationalfluiddynamics.com.au/tips-tricks-cfd-estimate-first-cell-height/
For your other questions please create a new thread.
April 28, 2019 at 7:33 am
LorenzoMazzei
hI,
Regards
Actually, the virtual wall shift approach should change the y+ value given the ks+ value. At that point the shear should be calculated depending on the new y+ value, using wall integration or wall function. Am I right?
April 28, 2019 at 10:25 am
DrAmine
Ansys EmployeeYes.
2596
2080
1317
1108
459
