April 24, 2022 at 10:21 am
SilverRD
SubscriberHi! I need someone advice does my Y+ acceptable?
April 25, 2022 at 12:08 pmMurari Iyengar
Ansys EmployeeThe Yplus values lie in the log-law region ie. 30April 26, 2022 at 7:20 amMay 3, 2022 at 3:46 pmViewing 3 reply threads- The topic ‘Y+ Graph Airfoil Upper and Bottom Surface (NACA0006)’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
