Y+ value
    • ashiadarsh
      What is the desirable value for Y+ plus for k-w SST turbulence model?I observed my numerical solution is matching with expt values for Y+ value close to 300
    • raul.raghav
      Ansys Fluent implements an automatic enhanced wall function for k-w models which is capable of handling of handling: (i) fine near wall mesh, Yplus<5 and (ii) coarse near wall mesh, 30.
      Note: When the viscous sub-layer needs to be captured in cases like transitional flow, separation, heat transfer, frictional drag prediction etc., the first cell has to be located within the viscous sub-layer and the y+ should be less than 1 (valid: y+ < 1).
      If you want more information regarding the y+ values and different near wall treatments, please refer:
      https://studentcommunity.ansys.com/thread/neat-wall-tratment/
    • DrAmine
       Please mark this thread as solved so that other members might take advantage of it.
