April 19, 2023 at 2:13 am
AISWARYA K P
SubscriberFor my model, the height of the building is 300m and the scaled model for fluent simulation is 1m. The velocity is 23m/s and I need to get a yplus of 1. This is my settings. But after simulation my yplus is getting as 150. Can anyone please help me in solving this.?
April 19, 2023 at 3:31 am
NickFL
SubscriberLook at how yplus is defined. What you are going to need to do is go back into meshing and refine the mesh where the values are 150. This iterative approach is typical as we do not know the solution beforehand and must guess an appropriate mesh size. Then we go back and refine the mesh after examining the results.
April 19, 2023 at 3:33 am
AISWARYA K P
SubscriberThank you so much. I will try the same.
April 19, 2023 at 9:42 am
Sascha Gross-Hardt
SubscriberUse inflation layers (prism layers) to provide adequate wall resolution if not already done. Particularly focus on the first element offset (distance to the wall) as it dominates the Y+ value and try to have a smooth transition from the inflation layers to the rest of your mesh.
April 19, 2023 at 10:58 am
Ansys EmployeeAs a comment. If you calculate the cell height to get y+ of 1, what is that cell height relative to the surface distortions (trees, cars, curbs, bushes etc)? The other comments answer your immediate question, but you might want to consider the rest of the factors before going too much further.
5162
3251
2443
