November 13, 2023 at 3:13 pm
pv00170
SubscriberI am analysing the reaction of a bridge under self-weight (Y direction). The bridge is halved, and a symmetry plane is applied to reduce computational time.
When I check the reactions, I get:
- X axis = correct (0 N)
- Y axis = correct (1.46 e6 N, which is the same as the self-weight)
- Z axis = ?? (5.12 e5 N)
I have some questions regarding the Z axis:
- Are these forces existent (even though no Z-direction forces are applied) because of the symmetry plane?
- Does this imply that if I run the model but symmetrically I should get the same Z but with the opposite sign?
November 13, 2023 at 4:57 pm
pv00170
SubscriberFor the whole bridge
I have compared some results. I have used Solution > Insert > Probe > Force reaction, and then I select Location method > Boundary condition and then Fixed support.
I have 16 supports, 8 on the left-hand side and 8 on the right-hand side. The following table shows the results of the reactions:
Whole bridge X (N) Y (N) Z (N) Left (8 supports) -3.83E+05 5.44E+06 1.24E+06 Right (8 supports) -3.82E+05 5.44E+06 -1.24E+06 Sum (by hand) -7.65E+05 1.09E+07 100 But then, if I consider the 16 supports altogether (rather than sepparatly) I get a different value:
X (N) Y (N) Z (N) Both (16 supports) -6.67E+05 9.41E+06 -1 For the symmetry bridge
I get the reactions of the 8 supports which multiplied by two, coincides with the previous one.
Symmetry bridge X (N) Y (N) Z (N) Left (8 supports) -3.33E+05 4.70E+06 1.66E+06 2 time left (by hand) -6.66E+05 9.41E+06 ? 3.32E+06 So my question also is: how come the addition of the 8 + 8 supports is not the same as the 16 supports?
- A solver pivot warning or error has been detected
8808
4658
3151
1680
1470
