Discovery Import
Discovery Import
Z Normal in DXF-DWG Export
    • ventura
      Hi, Recently SpaceClaim starts to export DXF/DWG in different way than before. Circles (holes) in DXF have a parameter called "Z Normal", it can be 1 or -1 (in our cases). Before latest version in the same exportation the Z Normal was 1 (or -1) for ALL circles. All circles had the same parameter. Now, with latest release, it's not the same. Some circles have "Z Normal = 1" and other "Z Normal = -1". This causes in some software (for Example Bysoft from Bystronic, one of the most important sheetmetal laser producer) errors. I'm not an expert on AutoCAD and DXF/DWG file structure, but  this propriety is visible in AutoCAD. Here the external circle haz Z normal -1
      Here the internal circle has Z normal 1
      Result on Bysoft, the shape isn't connected, seems Z-1 circles are mirrored
      Here the mirrored circles are visible, but sometime the risk is to produce part without some hole. Can you investigate with programmers? Thanks
    • ventura
      Here the files (you can try to generate the DXF from the STP)
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Subashni Ravichandran
      Hello DrkAngl
      Let me check with my team on this.
      Hello DrkAngl
      Could you try changing the SpaceClaim to Autocad export Translation Technology setting from 'Teigha' to 'Autodesk RealDWG' ? (refer image below)
    • ventura
      Customer tried to set Autodesk RealDWG as export format but it not solved.
    • ventura
       Here the 2 different DXF file (one created with Ansys SpaceClaim 2021 and one with SpaceClaim 2020).
      Can you ask to programmers?
      Hello DrkAngl
      I have reported a bug for this issue. Bug number 436851
    • ventura
      Hello Subashni any news about it?
    • ventura
      Subashni Please can you inform when a fix is available?
      Hello DrkAngl
      This bug is marked resolved for the upcoming version.
      • ventura
        Subashni customer want's to know if the fix is in Ansys 2021 R2 released after 9 September
    • ventura
      ok thanks
    • ventura
      Subashni I downloaded 2021 R2 Version and tried to export a DXF and I get the same result (mirrored holes).
      Can you verify with developers if they think the bus is fixed?
      Hello DrkAngl
      I have updated the development team that this issue is not resolved. I will keep you posted as I hear from them
      • ventura
        Subashni any news
    • ventura
      Please can you change status "NOT ANSWERED" ? Thanks
    • ventura
      The problem is not solved.
Viewing 14 reply threads
