September 28, 2018 at 7:58 pm
Sylvia
SubscriberHello,
I am trying to calculate J-integral and Energy release rate of an actual crack (not a crack growth model) by using ANSYS. Pre-Meshed cracked is the method I selected. However, for two same length crack, but just open in different direction, ANSYS gave me a total different result of G ( energy release rate).
Condition set: fixed support at bottom and 1 micrometer y direction displacement at top
1. Crack open at left side
Total deformation as following:
And I got J-integral = 66.19 and G total = 64.233
2. Crack open at right side
And I got J-integral = - 66.188 and G total = 0
Why changing crack open direction will lead to a zero energy release rate result? Please help me if you met similar situation before and know how to solve it.
Thanks a lot!
Sylvia
September 29, 2018 at 4:27 am
Sandeep Medikonda
Ansys EmployeeHi Sylvia,
How are you calculating the G (Should be completely from Mode 1, i.e., G1)? Are you using the Fracture Tool?
See if you can replicate this for the Fracture Example given in the manual?
Sandeep
Best Practices to post on the Student Community -
October 2, 2018 at 3:29 pm
Sandeep Medikonda
I was looking at a similar problem, please check the crack orientation coordinate system. Maybe the crack direction is defined incorrectly?
Sandeep
October 2, 2018 at 5:12 pm
Sylvia
SubscriberHi Sandeep,
You are right. I have reviewed the example given in the manual, and then tried many tests. I find out that if crack open in the right side, to avoid zero G value, I cannot set coordinate system at crack tip. If crack open in the left side, I can set coordinate system at crack tip...I still don't understand why. But finally I fixed my problem.
I do appropriate your help!
Sylvia
October 2, 2018 at 5:22 pm
Sandeep Medikonda
Have you tried transforming the co-ordinate system?
The x-direction has to be normal to the crack growth, so try making those changes and see?
Sandeep
October 2, 2018 at 5:57 pm
2066
1283
1096
459
