Creating an Inverted Pyramid structure
spacelover17spacelover17 Member Posts: 10
The Silicon TiO2 Pyramids Solar Cell example has been quite helpful. But I was trying to simulate an inverted pyramid structure similar to the one in this paper, and I am having trouble wrapping my head around how to construct this. Can someone please provide some tips? Thanks!
  • gsungsun Posts: 729Ansys Employee
    Hi, @spacelover17 , you can either rotate the existing group 180 degree around y axis and shift it to the proper position. this example uses old technique of layered rectangles; or you can build up your own periodic inverted Pyramid by your own using the pyramid in object library:
    what you need is to flip the sizes of the tip and the bottom:
    it can be a solid pyramid, or can be air by use of etch mesh order.
    Please try and let me know if it works for you.
