question important
HalimBishoyHalimBishoy Member Posts: 21
Can I ask how I can plot the efficiency in % of the metalens versus the wavelength band?
  • gsungsun Posts: 1,102Ansys Employee
    If you use broadband source, the transmission you get from a monitor is a function of wavelength. You can define your own efficiency and calculate from the transmission or E/H fields or Poyinting vector from the monitor, which are function of wavelength by default. Please first check your monitor and make sure it records data in the wavelength range.
    you can modify the frequency points to the value you desire.
