Ansys Insight: Adding Lumerical environment variables on Linux
LitoLito Ansys Employee Posts: 30
edited June 23 in Photonics
Guidelines for adding Lumerical environment variable or PATH into your user profile on Linux.
Notes: The process shown is using the bash shell and default Lumerical install path and settings.
  • Open Terminal
  • Use a text editor (vi, vim) and edit your .bashrc ,
cd ~
vi .bashrc
# Adding Lumerical and Python API path
export PATH=$PATH:/opt/lumerical/v211/bin:/opt/lumerical/v211/api/python
# Adding the environment variable, ANSYSLMD_LICENSE_FILE
export ANSYSLMD_LICENSE_FILE=1055@{license_server}
  • Save .bashrc and close the text editor.
  • Close terminal or terminate your session/connection.
  • Reconnect and open Terminal.
  • The new path with the Lumerical PATH and environment variable should show on your shell,
$ echo $PATH
/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/lumerical/v211/bin:/opt/lumerical/v211/api/python
$ echo $ANSYSLMD_LICENSE_FILE
1055@license_server
