How to import design parameters into Lumerical Mode?
Anish_MondalAnish_Mondal Member Posts: 7
I have used an algorithm on MATLAB to find out parameters for taper design as a dataset of point [x,y] for the taper. I want to import this to the Lumerical Workspace then build a taper using these points. But how do I import this data into the workspace? The data is saved in CSV format.
Thank You
Best Answers
  • Anish_MondalAnish_Mondal Posts: 9Member
    Do I have to write the entire MATLAB code which calculates the given parameters? So is it like we are writing the Matlab code via Lumerical script and then importing the variables from the Matlab workspace to the numerical workspace?
