6-DOF properties
SRASRA Member Posts: 2
For Half Section model : Spring Preload should be Half or Full ?
  • sdebsdeb Posts: 225Forum Coordinator
    When you say half section, do you mean cutting the spring into 2 halves (so 2 smaller springs)?
    In that case, preload should stay the same but check the spring constant. It might increase.
    I would suggest you to compare using springs in serial/parallel combinations to find this out.
    SD
