There is an issue trying to specify a license server that has a "-" in the hostname
Geo KarnosGeo Karnos Ansys Employee Posts: 4
on a client machine, using the Licensing Client Settings 2021 R1.
The Client Settings will not update the server if the hostname has a minus sign in it.
This is a defect and will be fixed in 2021 R2.
EX: Server-A
If you scroll over the Server1 input windows you will see:
The workarounds for this issue is:
1.     Edit the ansyslmd.ini file manually using notepad.
Default location is:
c:\Program files\Ansys Inc\shared files\licensing
/ansys_inc/shared_files/licensing
Change the hostname to the new hostname with the "-" in it.
2. Use the IP ADDRESS of the License Server.
