FLUENT application failed to initiate
This discussion was created from comments split from: Fluent application failed to start.
  • DinotanDinotan Posts: 1Member
    Hello, anyone knows what is the problem with this case? After I have done the meshing, it shows that the FLUENT application failed to initiate. And my meshing product did not show up at FLUENT, just a blank page. I had uninstalled it twice and redownload it, also turn off any firewall or antivirus program. Still facing the same problem. Pls help, thanks.
  • RobRob UKPosts: 9,687Forum Coordinator
    I suspect the question marks in the host ID and path are to blame. Change the save path and see what happens. Using "odd" characters with engineering software tends to cause problems as those characters may mean something on UNIX.
