Multi-core running failure
xyjxyj1992xyjxyj1992 Member Posts: 7
Hi, there is a job error popping out as shown in the attached figure every time I try to run with multiple core and threads. Can anyone help with this? Thank you!
  • gsungsun Posts: 1,652Ansys Employee
    It seems you have 4 licenses but your simulation tried to use 15 licenses! Please try to use only 4 nodes.
  • xyjxyj1992xyjxyj1992 Posts: 30Member
    I am confused... We only have purchased one license and that shouldn't limit the number of the cores we can use while running the simulation, right?
    It might be related to your license type. I will ask my colleague to investigate this issue further.
    Sounds good, thank you!
  • LitoLito Posts: 243Ansys Employee
    @xyjxyj1992,
    There is a limit to the number of cores you can run a simulation job. You currently have 1x Ansys Academic Lumerical FDTD research license that comes with 4 FDTD solve licenses. Each FDTD solve license allows running 1 simulation up to a maximum of 32 cores per simulation job. If you want to run a simulation with more than 32 cores this will require additional FDTD solve/engine licenses for each additional 32 cores increments. In your error message, it indicates you are trying to run a simulation job using more than 448 cores/threads (32 coresx15 solve license). Check your resource configuration to not use more than 128 processes when running a simulation job. See this article for details.
    Example: Running a simulation using 128 processes/cores on a local Windows PC. This will occupy all 4 FDTD solve licenses to run the simulation.
    I see, thank you Lito! I thought the processes and threads here indicated the number of processors and threads to use for the single simulation parallelly of my PC.
